01-12-2022, 09:02 AM | #1 |
Rep 385
M8 Wheels/Tires on a 540xi ( will they fit)
Hi folks, posted a similar question in the general forum. I have an opportunity to purchase a set of staggered 811m wheels for my 540xi M-Sport.
Wheel/tire are 275/35 r20 front 285/35 r20 rears. As per the seller all wheels are +28 ET. Will these fit my 540? Thanks. Last edited by peteinpa; 01-12-2022 at 09:39 AM.. Reason: Correction |
01-18-2022, 07:05 AM | #2 |
Rep 384
Drives: 16 X3 28d/18 540d xdrive
Have you any idea of the other measurements of these wheels other than the offset of 25mm? Specifically if the wheels are from the last generation of BMWs (i.e. F10), they will not fit?
Norris83282.00 |
01-23-2022, 10:34 AM | #3 | |
CEO
282
Rep 433
The fronts will fit no problem but a little aggressive. You can fit 9.5"x20 28mm with 275/35/20 front and rear on a g30 for a perfect fitment.
2018 M550I Xdrive Alpine White on Cognac Leather, Premium Enhanced Package, Drivers Assitance Plus, Remote Parking/display key, massage seats, 21 wheels style 629 Black Chrome. M performance brakes in blue, M performance carbon fibre diffuser, m performance side skirt extensions, m performance front lip. 45% tint, roof wrapped in gloss black.
01-23-2022, 05:01 PM | #4 | ||
Rep 385
01-23-2022, 05:42 PM | #5 |
Pace Car Driver
1557
Rep 3,166
So what did you buy?
01-24-2022, 07:15 AM | #6 |
Rep 385
I ended up with 706M wheels with tires. They have the Michelin high performance summer tires, which I am thinking of switching out. Rears are like brand new. Fronts have plenty of tread. I may opt of the Michelin all seasons so I can get 3 seasons on these. Will keep my 664 wheels and tires for winter.
G30 B581556.50 |
01-24-2022, 09:17 AM | #7 | ||
Rep 385
01-24-2022, 12:40 PM | #8 | |||
CEO
282
Rep 433
01-27-2022, 10:12 AM | #12 |
Rep 234
9.5 and 10.5" ET 28 will both be too agressive, especially rear ones. It will rub under load and it could be dangerous at high speed.
2018 M550i Sepia-Violet
01-27-2022, 12:54 PM | #13 | |
Rep 385
01-28-2022, 03:15 AM | #15 | |
Rep 234
This is a picture of mine with load trunk and my son at the back only, not much space left: Note that camber will increase under load, this is why it's ok for me, but really, there's no space left under the fenders. Below you can see the side walls of the tires poking out the fender: Different view: Your rear wheels will not only poke out by an additional 13mm (ET 28 instead of ET 41) that is a huge difference, they will also have a much bigger tires because of the profile (35 instead of 30). That means you're off specs at rear by 5%, which is a legal concern at this difference and is likely to cause issues with the DSC managing ABS, x-drive, traction control, etc... The calculator you used does not tell you it fits, it only shows the differences. At least it shows the speedo error, which is a first indicator of the issue since your are -3% front and -5.81% rear. Basic recommendation is to stay below 3% and also avoid significant différences between front and rear because of the x-drive which is calibrated stock with 0% difference and a small tolerance (unknown, unfortunately). The M5 has bigger wheel arches, wider body, updated suspensions and tuned DSC control unit to accommodate the bigger wheels. The BMW dealer who told you "it should be ok" is not your friend, and does not know anything about this (not a surprise). Even if you fit correct tire sizes for your car on these wheels, I suspect issues under load on the rear axle. It might be ok when you'll test in your neighborhood, but it will be different with people in your car when driving on a bumpy highway. Cheers
01-28-2022, 06:04 AM | #16 |
Rep 385
Thank you NTTY for taking the time to post and all the information you have provided.
The way I see it I have a few options. 1) Sell the set and move on. 2) Sell the rears and pick up a set of the 9.5 fronts as Norris suggested. 3) Mount a 275/35/20 on the 10.5 rims. All tires will be the same rolling diameter which should reduce xdrive issues etc... But will still poke and potentially run into the rubbing issue under load. The only question I have is that the M5 is also AWD and these are the OE sizes, so wondering if the Xdrive can handle it in the g30. When comparing the 275 and the 285 on the wheel calculator the speedo variance is .01% the diameter variance is about 1%. Plan all along was to replace the tires so I could go with 30 vs. 35 all around. Head hurting this early in the morning First world problems I guess. More to come. |
01-28-2022, 08:07 AM | #17 | |
Rep 234
The x-drive is obviously tuned on the M5. The electric motor closing or opening the x-drive multidisc clutch can be electronically adjusted in the x-drive control unit. I suppose this is how they adjust it to satisfy different rolling circumferences. In reality, and for all x-drive units, there are some small variations due to various tolerances. This is determined during production and a 4-digit code can be seen on the x-drive unit. This code is to be enter in the electronic control unit so that the correct pressure is applied by the electric motor to the multi-clutch disc. Our non-M cars are tuned to have the same tire diameter front and rear. The M5 has different diameters, even for winter wheels and tires (265/40/19 and 285/40/19). In your list of options, I see 1) as the easiest, and possibly 2). But you need to use proper tire sizes. 275/35/20 is off specs (4% increase) and would void the insurance in my country at least. Front should be 245/35 or 255/35 or 265/35. Rear can be 275/30, 285/30 or 295/30, or same as front, of course. Cheers
01-28-2022, 08:13 AM | #18 | |
Pace Car Driver
1557
Rep 3,166
Here's another thought to make them visually more appealing. Add the OEM fender guards or OEM extension that the M5(?) and or M550 have on them. Do you know what I'm talking about? You can get them in plastic (OEM) and even CF. Here's a link from IND: https://ind-distribution.com/collect...-extension-set |
01-28-2022, 09:43 AM | #19 | |
Rep 1,667
G30 B581556.50 |
01-28-2022, 11:00 AM | #20 |
Rep 385
01-31-2022, 01:56 AM | #22 | |
Rep 234
