12-15-2018, 11:25 PM | #1 |
Rep 4
Inner door panel removal
I was able to remove the door panel without any trouble. I was expecting to see the normal foam insulation, but instead found a hard plastic shell behind a fiber insulation. Anyone know how to remove the hard plastic panel to get to the wires in the door handle?
12-16-2018, 11:17 AM | #2 |
Rep 607
Post #6 in the thread below should help you. Fast forward about 10 minutes in.
https://g30.bimmerpost.com/forums/sh....php?t=1485900
Life is short...Drive fast
12-16-2018, 07:05 PM | #3 |
Rep 4
Thanks Dobie Dog. I didn't see anything in that video that will help me. I was able to get the panel off the door. What I need to do is remove the plastic panel in the picture above that is behind the insulation. I removed the 6 screws and loosened all the large white fasteners. That loosened it some but it was still attached in some areas. I was afraid to force it. I need to get to the wiring behind that panel.
03-26-2020, 10:46 AM | #5 |
Rep 1,147
Steps to remove it are shown in the door disassembly instructions on the below link:
https://www.newtis.info/tisv2/a/en/g...ont/1VnZ3URBXu |
