BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions E85 on stock fuel pump
      03-27-2024, 07:11 AM   #1
CT_M550
CT_M550's Avatar
Drives: '21 BMW M550
Does anyone know if you can run E85 on stock injectors and fuel pumps? Obviously with an OTS E85 tune.
      03-27-2024, 11:44 AM   #2
jeremiahadelphin
jeremiahadelphin's Avatar
Drives: bmw g30 540i
I Don’t think you can
      03-31-2024, 09:49 PM   #3
BlueBy
Drives: BMW M5
You can run E85 on your M550. I run it all the time on my wife's M550, but here is my trick:
* I pour in 1.5 Gallons of E85 to 15 Gallons of (e10 - 93oct) fuel; full tank
* Or, 1gal of E85 to every 10gal of (e10 - 93oct)
* Final ratio lands somewhere around E17; the car loves it!
* I pulled the exhaust flaps fuse for additional growl and those tail pipe are pretty much soot free
* Best 1/4 mile: 11.33@122 at the track. DA around 1700 - 1/2 tank of gas
* Car is stock except for BMC filters & charcoals removed
As you may know, E85 contains alcohol which helps clean internal engine parts, fuel lines, pump and injectors.
I've been implementing this E85 & E10 fuel mixing exercise for years with all of our cars and no issues whatsoever.
You CANNOT run 100% E85 with factory [stock] issued LPFP pump; you must upgrade and tune it.
Hope this helps.
