BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Tire Sizing Help for 20x9 et25 and 20x10 et30
      10-08-2020, 11:19 PM   #1
rswitch
rswitch's Avatar
Drives: 13' Alpine White 328i msport
Hi Everyone, Im looking to go wider tires for my vorsteiner vff-103
I currently have the stock 245/35 and 275/30 tires
and was hoping someone has advice on a wider and meatier size tires?
I was thinking of 265/35 and 285/35?
Any help is appreciated! thanks
rswitch ..
      01-06-2022, 03:58 PM   #2
Boosted_8
Drives: M550i
I have just taken delivery of 255/35/20 and 285/30/20 for 9 and 10 inch rims respectively.
      01-06-2022, 04:46 PM   #3
Superjackson
Drives: M550i
265/35 will not work with 285/35, it's too much of a difference in height.
The 265/35 will fit perfectly, it can be paired with a 275/35 which is perfectly good for 10" wheels and I'd recommend this setup.
295/30 would have a good height to pair with 265/35 but would not fit with your offset of 30 and a 285/30 is also too short to pair with 265/35 even though it would fit.
Another alternative is 275/30 front and 285/30 rear which should fit although it'd be aggressive in the front.
      01-15-2022, 11:54 PM   #4
rswitch
rswitch's Avatar
Thank you so much!! This is much appreciated!
rswitch ..
      01-25-2022, 08:04 AM   #5
NTTY
NTTY's Avatar
Switzerland
38
Drives: G30 M550xi
It is indeed a good idea to avoid significant diameter difference between front and rear for the Xdrive clutch, even if the DSC calculator can identify circumference differences and adapt.
Here you go with safe tire sizes:
245/35/20 and 275/30/20 (stock) and that is -0.96% for rear axle
255/35/20 and 285/30/20 (Alpina tourer stock) and that is -1.09% for rear axle
255/35/20 and 295/30/20 (Alpina sedan stock) and that is -0.22% for rear axle
Notes:
265/35/20 and 295/30/20 (suggested by Superjackason) means -1.23% for rear axle
265/35/20 and 285/35/20 means +2.02% for rear axle (don't do that)
Cheers
2018 M550i Sepia-Violet
      01-25-2022, 10:06 AM   #6
guyincogntioo
Drives: '22 M550i | '21 X7 M50i
Dinan recommends 265/35/20 and 295/30/20 on their 9et28 and 10et43 rims.
https://www.dinancars.com/products/w...0-0092-AR1-HYP
      01-26-2022, 07:53 PM   #7
rswitch
rswitch's Avatar
Notes:
Cheers
Thank you!
rswitch ..
      04-14-2024, 10:24 PM   #8
senya
Drives: 2023 M550i xDrive
I've ordered Alpina wheels (8.5x20 front and 10x20 rear). The site suggested the tires to go with it - for some reason stock size - 245/35R20 and 275/30R20. I haven't checked standard Alpina tire sizes until it was too late. So now I'm wondering if the setup of wheels and tires I got is safe to run on xDrive. Car to put it on is 2023 M550i xDrive. Wouldn't wider wheel size result in lower tire height?
