04-23-2024, 11:48 PM | #1 |
Rep 9
M550i Rear Seat Heating Retrofit
Hey all,
I was curious if there's any info on if G30 M550s come with pre-wired rear seats + come with all the heating elements by default? I bought an M550i recently that has almost everything I've been looking for...minus rear heated seats! So just curious on the prospects of retrofitting that feature. Thanks! Last edited by Cashews; 04-24-2024 at 12:45 AM.. |
04-24-2024, 02:37 AM | #2 | |
Rep 6,780
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
I would think this retrofit is more do-able than most. The rear seats are easy to pop out and get into to install the heat mat. Then it’s just getting the switch and coding. Wish I had some links or more information for you, it’s just not that common of a retrofit.
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
Cashews12.00 |
04-25-2024, 11:57 PM | #3 | |
Rep 182
Cashews12.00 |
04-26-2024, 11:32 PM | #4 |
Rep 9
04-26-2024, 11:37 PM | #5 | |
Rep 9
There's a few upholstery shops in the area that have worked on adding heated seats but not sure if they've really worked on BMWs. Appreciate the insight in any case, I figured it'd be a lot more work involved but it does seem more or less straightforward! |
