02-05-2024, 10:12 PM | #1 |
Rep 12
Trunk won't open with Remote or inside switch
Hello all
My 2018 540i's trunk stopped opening with remote, inside rocker switch and trunk touch button. I have checked the valet switch located in the glovebox and that's set to unlocked. Also My key fob battery is new and the car starts up just fine. I opened the trunk with the emergency handle and the trunk motor seems to run and the latch grabs and closes the trunk. When the trunk is open i can see the latch function when i press the key fob truck unlock button. I have checked the corresponding fuses and they're all good. Has anyone run into this issue, or have any ideas what to try next? Thank you |
02-06-2024, 07:14 PM | #2 |
Rep 36
BMW 51248737952 Spindle Drive, Right
this is official name of part which does power lift and power close. Mounted on R side attaches to vicinity of tail light and trunk hinge on R side. L side is spring loaded, R side spring loaded and power operated. Access to is as you would fuse box in the trunk. |
gongodefoy1.50 |
