BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions Lost trunk kick function with diffuser
      01-02-2019, 02:21 PM   #1
Mach550
Mach550's Avatar
Drives: 2019 M550i
2019 BMW M550i  [8.00]
It seems like ever since I unplugged the system to install a rear diffuser I have lost the kick function. I ensured that everything is plugged in correctly but I still can't get the kick to work. Are there issues with unplugging certain items while the car is unlocked? Physically there isn't much of a difference between where the system was in the OEM position and the new diffuser position. Also not sure if I should unplug the batteries for a couple minutes to clear out whatever bugs are lingering, this cars electronics make me worry about unplugging the battery.
      01-02-2019, 06:53 PM   #2
drjolokia
Drives: 2019 M550i
I've done a lot of research on this. I've talked with a BMW service Foreman and no one can seem to tell me why but installing a rear diffuser disables the kick trunk function.
This is true for the bmw m Performance diffuser and other 3rd party diffusers.
All I can find out is that it happens but not why it how to prevent it from happening.
That's why I decided to wrap the gray part of the rear bumper instead of installing a diffuser. It looks really good (not quite as good as a nice diffuser) and the kick trunk function works.
      01-02-2019, 07:45 PM   #3
Mach550
Mach550's Avatar
Drives: 2019 M550i
Only thing I can think of is maybe the way the cables were wrapped behind the oem diffuser was specific to its operation...I'm going to see about playing with it this weekend.
      01-02-2019, 07:51 PM   #4
drjolokia
Drives: 2019 M550i
Cool. Let us know how it goes.
      01-08-2019, 09:37 PM   #5
Mach550
Mach550's Avatar
Drives: 2019 M550i
so I found that if I kick directly where the module is on the right side of the diffuser it seems to work.
clee1982797.50
      01-08-2019, 10:36 PM   #6
drjolokia
Drives: 2019 M550i
Nice. Glad it's working.
      01-09-2019, 07:48 PM   #7
M550iG30GUY
M550iG30GUY's Avatar
Drives: 2019 BMW M550i
Strange. I find it that it works intermittently closer to the driver side. It's worked twice. Haven't been able to do it since. I have been using it on my old f10 550i and miss it in the new car. I have the M performance diffuser and i ordered the car with it, so it was installed at vpc by bmw. Hope someone has a fix for it soon.
      01-13-2019, 06:19 AM   #8
prince1566
prince1566's Avatar
Drives: 2018 530i M Sport
Which diffuser do you have? Mine still works with this one.
      01-15-2019, 01:39 PM   #9
Mach550
Mach550's Avatar
Drives: 2019 M550i
I have the AC Schnitzer diffuser
      05-02-2019, 07:13 PM   #10
dlf750
Drives: 2019 BMW 540i M Package
I bought 2 diffusers off ebay - the first one, which I returned, made the kick non-operational. The second one works perfectly. Very odd...
      02-22-2020, 05:47 AM   #11
thomaswang573@gmail.com
Drives: 218 i
i think the problem is caused by the distance of the signal ranges. make sure the location where it is,then find the reason
      03-07-2020, 06:15 PM   #12
dlf750
interesting... not sure what you disconnected or why. I installed a rear diffuser and didn't disconnect anything. Now, there are times, not often, where the kick feature doesn't always work but I did find if I touch the tip of my foot to the bottom of the diffuser there's never a problem with it working.
      07-20-2020, 02:24 PM   #13
The Zimmer
Drives: BMW G31 Touring
Hey all
I know when installing the genuine BMW M performance diffuser you need to code it to the car and then the comfort access works perfectly. This apparently does not work at all with the carbon one
Paul
      03-27-2021, 06:47 PM   #14
mittu
Drives: 530d xdrive
Think it may have to do with the increased amount of plastic between your foot and the sensor.
      03-27-2021, 07:16 PM   #15
mittu
Drives: 530d xdrive
That's a nice diffuser. Where'd you pick it up from pal?
      03-28-2021, 02:56 PM   #16
Sophisto540
Sophisto540's Avatar
92
Drives: BMW 540i
2017 BMW 540i  [0.00]
prince1566 +1 on the question about that really aggressive looking diffuser!
      11-27-2021, 05:25 PM   #17
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
This happened in my f10 as well. Never figured out why it stopped working but honestly not a big deal. I mean who actually uses it. I mean you kinda look stupid using it anyways.
      11-30-2021, 01:43 PM   #18
steveward
Drives: 530e
theres a youtube video of a guy fixing the problem of losing the kick function after fitting diffuser by spacing the lower half of the diffuser with plastic washers if its a 2 piece diffuser, not sure how that fixes the problem but its a good informative video
      11-30-2021, 01:51 PM   #19
steveward
Drives: 530e
link for video https://www.youtube.com/hashtag/diylife
      11-30-2021, 01:52 PM   #20
steveward
Drives: 530e
direct link but type in Foot Kick Trunk Open/Release Fix on F80 M3
      12-05-2021, 04:52 PM   #21
430Scud
430Scud's Avatar
241
Drives: M550iX,430 Scud,E39 540Msport
