10-24-2020, 03:35 PM | #1 |
Rep 158
Assisted Driving View
Does Assisted Driving View (i.e., the active visualization of nearby vehicles in the driver's display when Assisted Driving Mode is enabled) come standard on an 2021 X7 M50i that is equipped with Driving Assistant Professional package ($1700 USD)?
My client advisor said yes, but with some hesitation, so I'd like additional confirmation. |
10-25-2020, 11:05 AM | #2 | |
Rep 2,935
10-25-2020, 11:29 AM | #3 | ||
Rep 376
Resjudicata1599.00 |
10-25-2020, 11:36 AM | #4 | |
Rep 1,587
Resjudicata1599.00 mrichione94.00 |
10-25-2020, 04:34 PM | #5 |
Rep 18
10-26-2020, 01:26 PM | #6 |
Rep 1,587
Resjudicata1599.00 unfoundnemo1901.50 |
10-28-2020, 09:08 AM | #7 | |
Rep 134
10-31-2020, 12:46 AM | #8 |
Rep 331
i have X7 2019 with iDrive version 03/2020.58 and Driver assistant professional can visualization be activated?
Prod. Date 2019-06-15 Type X7 40iX Series G07 (X Series) |
10-31-2020, 01:51 AM | #9 |
Rep 1,587
10-31-2020, 01:07 PM | #11 |
Rep 158
@ifr How challenging is it to code? I also have a 2019 X5 running 07/2020.xx software without it.
11-01-2020, 04:33 PM | #12 | |
Rep 134
Go under "Instrument Cluster" Module, and click expert mode and search for below values and change them to aktiv (01) CB_FZG_UMGEBUNG_FAS: aktiv (01) CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG: aktiv (01) PIA_FZG_UMGEBUNG_FAS: aktiv (01) SICHT_ABSICHT_ENABLE: aktiv (01) |
11-01-2020, 06:13 PM | #13 | ||
Rep 158
swissguy |
11-02-2020, 03:05 AM | #14 | |
Rep 1,587
1. Assisted Driving View (ADV) with Assisted Driving active and/or 2. ADV active whether Assisted Driving is engaged or not i.e. all the time Not everyone has been able to code all the options, but you usually have the option in i-drive to make ADV active at all time. TLA etc cannot be coded with Bimmercode. You need esys, esysx and the coding to do that. |
mrichione94.00 |
07-18-2022, 08:36 PM | #15 | |
Rep 1,497
07-18-2022, 10:35 PM | #16 |
Rep 991
What is the use of this information? My 2019 didn't have it, but my 21 does. While it's entertaining that it identifies tractor trailers and I can see them in the center display, I'm not sure what seeing this does for you. I look out the window and amazingly, yep there they are.
07-18-2022, 11:54 PM | #17 | |
Rep 440
Drives: '20 X7 M50i, '21 M340i
2020 BMW X7 M50i
2021 BMW M340i 2023 Mini Copper Countryman JCW 2023 GMC Sierra 1500 |
07-19-2022, 12:10 AM | #18 |
Rep 1,206
Would you please elaborate on this. For example...I like a feature that other car manufacturers have...you can flip the rear view mirror to a display connected to a camera...you can see the traffic behind and surrounding the car while driving at any speed. Would the Assisted Driving View accomplish something close to that? Thanks in advance.
07-19-2022, 05:40 AM | #19 | |
Rep 514
Brigitte484.50 |
07-19-2022, 08:26 AM | #20 | |
Rep 1,206
07-19-2022, 10:28 AM | #21 | |
Rep 514
1. With cruise control, this display will replace the map view in the instrument panel. It will show you the nearby cars. The automated lane change uses it to change lanes and if it detects a car is the next lane, that car will turn yellow and the lane change feature won't occur until that car is no longer a factor. 2. The Assist Plus feature which is shown in this video is used only below 40mph. It's for traffic situations and allows you to be completely hands off driving, as long as the camera detects your eyes. It will still monitor you to ensure you're being "alert." Normal cruise control only allows you to be hands off the wheel for 7 seconds. This feature when activated, once again below 40mph, allows you to be hands off the entire time. Bottom line, I would just search for all of this on BMW YouTube channel if you want to know more. They walk through all the different features. |
07-19-2022, 01:46 PM | #22 |
Rep 440
Driving Assistance Professional Package (has below two options)
• Active Driving Assistant Pro • Extended Traffic Jam Assistant for limited access highways blutob2 had described it
2020 BMW X7 M50i
