E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335D - Do air scoops do any good?
Reply
      12-23-2010, 04:39 AM   #1
koreez88
Всем привет ;)
Drives: Tesla
New lucky owner of 2011 335D here.
Since diesel relies on air to create combustion inside the engine, would that mean that air scoops should create a fairly dramatic increase in car power? I've transfered my old MDF scoops from my ex 325i and haven't driven the car yet due to quite nasty weather. But some knowledgeable feedback would be great.
      12-23-2010, 05:30 AM   #2
Bimmer84
Guardian of the Night
Bimmer84's Avatar
Drives: 2010 335i M Sport Coupe
2010 335i E92  [7.50]
Sounds logical although I've heard you don't notice your big power increase with scoops until about 70mph+. Never owned any though and not sure if diesel would be a differencing factor...
2010 335i M Sport Coupe -- Black Sapphire Metallic|Coral Red|Loaded|JB4 Stage 3|BMS DCI|VRSF DPs|Camaross 6k AE|Performance Gloss Black Grilles|CF Performance Spoiler|CF Quad Diffuser|Double Layer Black Chrome Quad Tips|CF Roundels|Smoked Reflectors|Red Cyba Scoops|193s Painted Lamborghini Metallic Dark Gray
      12-23-2010, 07:02 AM   #3
chiaobaby
chiaobaby's Avatar
Drives: 335i
Smile
scoops will not make a difference especially on a TURBO CAR it is being force feed already.
      12-23-2010, 07:27 AM   #4
E90jonno
STANCE YOUR RIDE!
E90jonno's Avatar
Drives: E90
Would a pannel filter not be a better buy?
      12-23-2010, 09:35 AM   #5
cgom3z
IG: cgom3z
cgom3z's Avatar
Drives: E36 M3, E92 M3, F06 M6
I havent seen any gains to speed or power after 70+ mph; however, they do look good.
IG: cgom3z
      12-23-2010, 09:54 AM   #6
hipnotic
hipnotic's Avatar
Drives: e92 335i
2008 335i coupe  [7.00]
nothing under 70 mph
      12-23-2010, 11:28 AM   #7
SV Concepts III
Drives: BMW Duh
It's difficult to dyno the improvement as these are only functional at speed but they do help with channeling more air into the intake system.
      12-23-2010, 11:55 AM   #8
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
+1 people need to stop wasting money on scoops on a car that has turbo - the scoop will not feed more air into the engine in any scenario ever!
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      12-23-2010, 11:57 AM   #9
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan; BMW M3 ZCP
2018 BMW M3 ZCP  [0.00]
2007 BMW 335Xi  [0.00]
+2
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps)
†Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec
AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS
      12-23-2010, 03:15 PM   #10
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
VAC or JBD for you my friend
      01-18-2011, 04:35 PM   #11
tibra1
Drives: 2011 ZCP M3 - 2007 335i crashd
Not into the engine directly... but wont it provide more air through the intake to then be compressed into the engine by the turbos? I am on the fence with this mod..i am thinking to get the CYBA scoops..they are only $39!
      01-18-2011, 04:46 PM   #12
Shellacked135i
Drives: 2010 135i, 09 335xi
The scoops power increase is negligible but it shouldnt take power away. ITs not a waste of a mod, but there are other modifications which actually might yield some in the seat of the pants power. I would invest in an intake or panel filter first. In reality a intale/panel filter and tune first.
      01-18-2011, 04:54 PM   #13
tscdennab
Drives: BMW 335i
2008 BMW  [6.24]
My belief is that because of the water radiator being in the air path and restricting air flow, a positive pressure is created in front of the radiator anyway (with or without scoops) so the air in need of an easy escape path is forced through the intake snorkel regardless of scoops being present or not.
Anyway, looking at the Cyba scoops they are a bit too large for my liking. They cover too much of the radiator. If you choose them, maybe you can trim them somehow.
      01-18-2011, 07:17 PM   #14
tibra1
Well that goes w/o saying scoops by themselves will do nothing ...I am trying to decide whether to use the scoops w my simota closed air intake.. here is a pic..I think the scoops may really help feed air into the intake or its going to really just scoop bugs and debris..lol..im still unsure
Thoughts?
      01-18-2011, 07:19 PM   #15
tibra1
Great point..i may just opt to run the intake w/o the scoops
      01-19-2011, 02:07 PM   #16
WilliamE92
WilliamE92's Avatar
21
Drives: 2013 EB F30 335 MT
Things which ram air intakes actually make a difference on:
      01-19-2011, 02:49 PM   #17
Thud
Throbbing Member
43
Drives:
The negligible power increase you'd get (over 70mph), especially on a turbo car, is probably going to be offset by the additional weight of whatever ram-air ducting is installed.
For performance improvements, you're probably going to get better results by just removing the rear floor mats to lower weight. Or emptying your bowels before you drive. In other words, it's not going to make any difference outside of the margin of error.
Now, install a JBD, and that's another story....
2014 Tesla Model S 85kwh
Previous cars:
2011 335d / Deep Sea Blue / Saddle brown / sport / premium
2008 BMW 135i / 6MT
2002 Z06 Corvette
      01-19-2011, 06:13 PM   #18
dcorn
Drives: 2008 E90 335i
lol, I bet all the people saying scoops are pointless have upgraded air filters too. What do you think that does for the engine?
      01-19-2011, 06:17 PM   #19
Shellacked135i
Thoughts?
Attachment 476371
Attachment 476372
I dont see it hurting performance, I have scoops. I noticed on avg a 5-10 degree intake air temp reduction. When I used a stock intake with the scoops I noticed a good throttle response. Again, they shouldnt really hurt performance. Like I recommended above, I would get an intake or filter first, then throw scoops on.
The cyba scoops are like $40, I lost more money in a bar personally, so oh well.
There is a theory of a pressurized area w/out scoops and as much as it might be true i think a lower resistance air pathway would flow better air, as opposed to waiting for a pressure build up in the front of the radiator and possibly taking some heat from radiator itself. Who knows I'm not a fluid/aerodynamic engineer.
      08-31-2011, 02:42 PM   #20
E90Brad
E90Brad's Avatar
Drives: SQ5
I am not a fluid/aerodynamic engineer, I am also a crappy physicist... I even had to look up the spelling of physicist but I have something to add futher to what Shellacked has said.
There is a relationship between pressure, tempature and volume in thermodynamics (pv=nRT). Let's assume related rates (air into engine and air going into intake) are negligible.
Without scoops, air is being forced into an area of consistant volume (ie stock airbox) with an (assumably) relatively consistant temperature. If we assume that volume and ambient temp remain the same then we can use some logic to make an guess at what is actually happening when we add scoops.
Now we add scoops. If we assume that the scoops channel more air into the intake box (which I think is correct), then the increase in air should cause an increase in pressure (constant volume of airbox) which in turn will cause a decrease in intake temperature.
I would think that this effect would be greater with a stock airbox as the closed in area would allow air pressures within to increase. Those with upgraded intakes should see a lesser effect as the intake temperature would be manipulated by the engine temperature and there is usually no confined volume for pressurization to take place.
Now this is only one arguement. You could also argue (as someone has previously done) that the scoops get air from a (slightly) lower height and that contributes to lower air intake temps.
I am thinking of grabbing some Cyba scoops and looking at the difference in air intake temps and maybe even 0 - 100 times using a stock airbox and then a DCI.
Just my 0.02 on air scoops.
      09-01-2011, 08:08 AM   #21
Thud
Throbbing Member
43
Drives:
If you compress air, it heats up, not the other way around.
As a matter of fact that's how diesels work. Remember the ideal gas law: p*V = n*R*T
All else being equal, if you increase pressure then temperature also goes up.
As I said in my last post a few months back, any negligible power increase will be offset by the increased weight of the equipment you need to install, as well as the increased drag coefficient you'll have.
You'll get better results by simply reducing weight: i.e. removing the toolkit from the trunk, losing 5 pounds of beer gut, or driving naked.
Previous cars:
2008 BMW 135i / 6MT
2002 Z06 Corvette
Reply
e90post
