BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions No more engine start/stop disable for 2021, WTF!
      12-18-2020, 08:30 PM   #1
Thornton Melon
Drives: 2021 BMW 540i
I have a 2018 and I'm used to simply disabling the engine start/stop function every time I start the car. So, since my lease is expiring in 3 months I went to test drive the 2021 today. I immediately noticed that the disable button is gone and there's just a blank plate. I initially thought this was great, it's back to the good ol days when we didn't have to deal with this. I get to the first light and the engine cuts off. I asked the salesperson how to kill it. He said there's no way to turn it off anymore, you just have to live with it. This is the first modern car I've driven or been where you can't disable the start/start. What a disaster.
      12-18-2020, 09:13 PM   #2
PsiAddict
Drives: 2019 X5 40i 2019 C7 GS
I have a 21 and it has the start/stop disable right next to the on/off button...
      12-18-2020, 10:11 PM   #3
Thornton Melon
My bad, I meant to specify it was a 2021 540i. Is that what you have? I noticed a 2021 530i that had the disable button.
      12-18-2020, 10:12 PM   #4
PsiAddict
No, M550i. That would be odd if only certain models did. You’ll just have to code it out.
      12-18-2020, 10:58 PM   #5
marsb007
marsb007's Avatar
Drives: 2024 iX M60
Mild hybrids or plug in hybrids don't have the ASS button. My plug in didn't, because it didn't need it. Same with the mild hybrids. The M550 still has it, since the V8s didn't get the mild hybrid technology.
KoenG1428.50
leon360x139.50
      12-19-2020, 12:07 AM   #6
Thornton Melon
Thanks for clarifying. This new mild hybrid system on the 540 smooths things out a little bit but it's still very noticeable and abrupt, hate it.
      12-19-2020, 12:58 AM   #7
COBodom
COBodom's Avatar
603
Drives: 2024 540i
In absence of ASS ON/OFF button, you can customize Sport Individual mode and set all of its categories into "Comfort". Next time you get in the car you just switch into that customized Sport Individual mode and engine wont shutoff anymore.
Its prolly something that can be coded too.
Current: 2024 540i MSport
Prior: 2021 540i MSport, 2018 540i MSport, 2015 BMW 528i MSport, 2012 BMW 528i
      12-19-2020, 02:11 PM   #8
Thornton Melon
Yeh, good work around, thanks. It was just so easy before. With one swipe of the finger you can turn on the car and turn off ASS. Was like not having it at all. Maybe I'll just get used to the new mild hybrid technology.
      12-19-2020, 02:13 PM   #9
hlothery
Seeking mental floss
482
Drives: 2022 Mercedes EQS 450+
Also, moving the shift lever left to put the transmission in sport (which is how I usually drive) used to disable ASS. Does that still work with the 2021? If so, problem solved for me.
      12-19-2020, 05:22 PM   #10
Jas387
Drives: 2023 M5 Competition
It does still work in the 2021. I've learned to do that when I get to junctions where I might need to pull away quickly into a gap etc.
I've programmed my Sport Individual to be the same as comfort mode (apart from the steering, which I prefer slightly heavier), so if I want to enjoy driving a bit more, I change to this mode, or one of the actual Sport modes.
Having said all this, I am slowly getting used to the ASS. The biggest annoyance to me is the delay accelerating out of a bend if I had been coasting, or the engine cutting out just as I was about to pull out onto a roundabout etc. No doubt its better for the environment, but it is so effective at shutting the engine off that it can be frustrating at times.
      12-20-2020, 01:13 AM   #11
Thornton Melon
As much as I want another 540 I may get a 530 so I can have the ASS button. I'm in LA traffic most of the time anyway so it's fine for my needs 99% of the time and the options list is exactly the same as a 540.
      12-20-2020, 03:47 AM   #12
Jas387
Programming the sport individual setting means you’d still have a one button solution to turning the ASS off - it’s just down by the gear leaver rather than under the starter button.
From what I can tell, once you’ve set it up, it’s exactly the same.
      12-20-2020, 12:19 PM   #13
Thornton Melon
I hear ya, not happy about the location but guess that's the only option if I wanna go 540.
      12-27-2020, 11:23 PM   #14
Up4speed
Up4speed's Avatar
Drives: 2021 M2C
2013 Ferrari 458  [0.00]
2015 Golf GTI  [0.00]
Did anyone figure out how to code it so the car remembers the last setting?
I use the Sport Individual trick to keep it from activating the ASS, but I find it annoying to hit that button every time. It would be nice if the car defaults to the last setting.
      12-28-2020, 01:34 PM   #15
530iDriver
530iDriver's Avatar
Drives: 2017 BMW 530i
My 2017 530i has ASS permanently disabled
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness....
      12-28-2020, 05:10 PM   #16
Up4speed
Up4speed's Avatar
Drives: 2021 M2C
Thanks for rubbing it in!
LOL< just kidding. The 2021 540i's are different. The ASS button is missing, and the only way to shut it off, is to put it in Sport mode EVERY time you re-start the car
Hopefully someone can give me instructions on coding out the start/stop completely, or at least to remember the last drive setting, so it will start the car on "Sport Individual" every time, unless I change it.
      12-28-2020, 06:55 PM   #17
marsb007
marsb007's Avatar
Drives: 2024 iX M60
You can't code the car with Bimmercode or Esys to start in Sport?
      12-28-2020, 08:43 PM   #18
Up4speed
Up4speed's Avatar
Drives: 2021 M2C
I'm not sure. I'm a beginner with Bimmercode, and was hoping that someone would be able to give me guidance. I don't want to screw anything up.
      12-29-2020, 07:42 AM   #19
marsb007
marsb007's Avatar
Drives: 2024 iX M60
You can code the car to start up in whatever mode you want. The easiest way is with Bimmercode. I had my 530e coded to start in Adaptive and now my 550 is Adaptive as well. It literally takes 5 minutes.
You should probably jump over to the coding forum as well. There are plenty of videos on YouTube about Bimmercode.
If you're still apprehensive, pay one of the coders on the forum to remotely log in and do it for you, but that will require a windows laptop, EsysX and an Enet cable.
Either way, my 550 has the ASS. It's not the smoothest start/stop as I had in the 530e electric, but it doesn't bother me all that much. It only comes into play when I'm at a light. Depending on your drive, if you're in heavy traffic, just hit the button to disable it.
      12-29-2020, 08:06 AM   #20
SteveinArizona
Drives: BMW 530e
There is, however, a difference between the plug-in and the mild hybrid. On my 530e plug-in, when stopped the car reverts to the electric motor so if one does not activate auto hold or keep ones foot on the brake, the car will crawl forward. Just as cars have always done for 100 years. So even if one has been driving with the ICE, when stopped it reverts back to the electric motor.
      12-29-2020, 08:12 AM   #21
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3000
Drives: CT5V-Blackwing
That's my biggest gripe with my car (2019 non-hybrid 540i) is that when you come to a stop, the engine seems to cut off right before the car stops moving, causing a little lurch as the brakes are no longer working against the engine. For this reason I turn off (and have set coding to remember that it's off) the ASS, which is an appropriate acronym, IMHO, LOL, etc.
The restart is very smooth though.
If it turns out that this is something that I will not be able to disable on my future 2022 replacement (at lease end) and the Mercedes or Audi does a better job on it, then I may have to jump ship.
Current inventory:
F22 & G05
Cadillac CT5-V Blackwing w/3 pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
      02-11-2021, 02:45 PM   #22
Nadz
Drives: G30 530d
Just getting used to my 530d with MHT. I had a loaner recently and I'm sure the engine started (without touching anything) when the car in front moved. My MY21 doesn't seem to do this. Anyone whose car does auto start when cars in front move? I don't have the driver assistance pack.
