07-17-2022, 01:38 PM | #1 |
Rep 59
Drives: 2023 BMW 530e
Coding Bowers and Wilkins from another G30
Has anyone replaced a Hi Fi system with a Bowers and Wilkins (both the speakers and the Amp)?
I've played with Bimmercode and there was some setting that looked like Bowers and Wilkins in German, and it enabled an EQ. Of course the EQ did not do anything to the sound because I don't have the hardware. If I pick up the hardware some place, and install it, does anyone know how hard it is to enable it? Do I have to goto the Dealer? Or can I just use BimmerCode to make the magic? In my son's 2012 Jeep, putting in a new radio required some kind of a radio ID code generated from the VIN or something. To project against theft. Is the BMW like that? Thanks! Ethan- |
07-17-2022, 02:49 PM | #2 | |
Rep 1,658
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
07-18-2022, 05:09 AM | #3 |
Rep 390
I think it will likely be difficult and expensive for you to find the B&W components. If you have the Hi-Fi system (not the Harmon), then probably your best bet is to use a solution from Bimmer-Tech. Enter your VIN at their website: https://www.bimmer-tech.net/speakers...lifier-for-bmw
Bavsound also makes very nice speakers. Some get the Bimmer-Tech amp, but use the Bavsound speakers. But this may require more amp configuration with the software made for adjusting digital signal processing of the Bimmer-Tech amp. Either option gets you better than Harmon Kardon sound, but not up to B&W sound. The weakness is really the amplifier. Both the Bimmer-Tech and the Harmon amp are around 600 watts where the B&W amp is more than double that. There are lots of YouTube vids on Bimmer-Tech installations. I recall one by Kies Motorsports that was pretty good. Bottom line, going with an all Bimmer-Tech solution will be the easiest and most cost effective way to upgrade from Hi-Fi.
2020 540i MSport | Alpine White | Mocha Nappa | Aluminum Rhombicle | Exec Pkg | Luxury Seating | Bowers & Wilkins | Parking Assistance Pkg | MSport Brakes | Ceramic Controls | Space Saver Spare |
07-18-2022, 05:20 AM | #4 |
Rep 6,825
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
Honestly, I am an online G30 junkie who is all over forums and Facebook groups. Many have asked this question and I know no one who pulled the trigger on procuring all the hardware. Coding is not the issue, that is the easy part. Cost and level of effort is just way over the top. Just put it on your list for the next car. I know no one who has retrofitted it for good reasons. It's not just speakers, subs and an amp. You are looking at a new wiring harness that needs to go to EVERY speaker point as well as the amp.
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
07-18-2022, 08:30 AM | #5 |
Rep 385
I installed the bimmertech amp, also installed bimmertech subs as well as rear deck and center. I
Picked up B&W after market for front doors with the leds. Sounds much better then the hi-fi system. Recently drove an 840 with HK. Mine sounded just as good or better but sound is subjective. Have not heard the B&W live so cannot comment but take the word of many on the forum regarding the B&W being best. One other consideration. The bimmertech amp can be tuned to your liking. You can either diy or provide them with feedback and they will send you a tune you can download. I usually opt for the latter. |
07-20-2022, 07:48 PM | #6 |
Rep 471
In addition to the obvious speakers and amp there are active crossovers in each front door that would need to be added to have the complete B&W system. If I didn't have it, it would not be something I would have tried retrofitting. Definitely easier to go aftermarket kit or DIY a custom setup (which could easily exceed the sound of the Bowers if done right).
12-29-2023, 09:53 AM | #7 |
Rep 3
Have anyone tried coding bowers and wilkins menu and sound menu into idrive 6? I tried to code through bimmercode, but I couldn't access it due the headunit being coded before.. So I am left with an option, just taking car to shop and let them update the idrive, so I get a full screen apple carplay and after that code bowers and wilkins menu, just so it matches the b&w covers in the car and to have a oem looking menu, in addition with more advanced equaliser and different sound stages.
12-29-2023, 10:24 AM | #8 |
Rep 45
I happen to have a spare B&W amp from my previous M550i, and my new one is HK...I haven't poked around to see if the connections would physically support swapping the amps and subsequently the speakers out, and I think there could be a bunch more other components needed to physically enable such a swap, in advance of coding.
I own my car but don't want to risk exploding the Hk as it stands...chicken meet egg time, I guess. I also think if a higher powered amp for the factory hk came out I'd be all over it. It's very under powered... |
Tags |
530e, bimmercode, bowers and wilkins, g30, sound |
