04-18-2020, 08:11 AM | #2 | |
Rep 100
My car "suggests" the new speed, when I touch the dial on the steering wheel it adapts to the suggested speed. Do you expect it to-do that automatically? Or is it that I described you try to get working? |
GermanCarGuy7.00 |
04-18-2020, 08:40 AM | #3 |
Rep 5,025
Is this already fitted to the car and you are seeing there other options I official options avail via the coding route or are you trying to code this as it was not an option specified at build time?
Previous post describes what it does, you can choose to use it or not by specifying in idrive |
04-18-2020, 11:18 AM | #4 | ||
Rep 25
04-18-2020, 11:19 AM | #5 | |
Rep 25
04-18-2020, 12:52 PM | #6 | |||
Rep 1,587
Manual SLA is available on the G30 but I've not looked into coding that on a 5 series. |
GermanCarGuy7.00 maximking107.50 |
04-18-2020, 12:54 PM | #7 | ||||
Rep 25
01-02-2022, 11:05 PM | #8 |
Rep 560
Did you get it to work? Every thread I find about SLA or aSLA seems to be for an LCI G30. Mine is a 2018 and I don't know what to code. The newer cars mention an SAS module which I do not have. Although I have everything else, for level 2 autonomy. 5AT + 5DN
01-03-2022, 09:39 AM | #9 |
Rep 4,210
Here, almost everyone drives over the speed limit and the photo radar only kicks in at 10 mph over the speed limit. The feature would only be useful to me if i were able to set the amount over/under. In my case that would be 9 miles over.
I do wish that the colors didn't change when I went over the speed limit. A little annoying but I have gotten used to it. |
01-03-2022, 08:33 PM | #10 | |
Rep 468
01-03-2022, 11:52 PM | #11 |
Rep 5,025
In the HUD if you exceed the speed limit by 1mph or more, the speed displayed changes from white to red.
I think you can turn on this feature in idrive if I recollect correctly. |
SteveinArizona3086.00 |
01-04-2022, 01:36 AM | #13 |
Rep 560
What other codes did you change? Everyone keeps saying ID7 is required, but you're running ID6, so I'm trying to copy you. If you help me get that screen, I'll help you get the rest to work.
01-20-2022, 04:30 AM | #14 | |
Rep 335
Additionally, auto update or suggestion to update the cruise control speed doesn't work. At least I couldn't activate it no matter how many codes I have tried.
2017 G30 520 (1.6lt)
2016 S1000RR 2014 W205 |
The-Traveler137.00 |
01-21-2022, 10:47 AM | #15 | ||
Rep 560
01-21-2022, 12:31 PM | #16 |
Rep 4,210
Where in Idrive? I have looked and not seen it. I want to see the speed limit but I want it to stay the same color and I will adjust my speed as necessary. I don't need a red sign blasting at me when I drive the same speed as everyone else.
02-13-2022, 01:29 PM | #18 |
Rep 560
Are there clear instructions for getting speed limit assist working on ID6 pre-lci g30? I'm happy to code it, but I don't want to experiment with different settings if it won't work.
