BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Gentleman switch function active ?
      02-02-2020, 08:10 PM   #23
mokorx
Thailand
51
Drives: G30 530e M Sport, F30 316i
Will this function work if the passenger seat has no memory function?
      02-19-2020, 12:19 PM   #24
NeuBob
Drives: BMW 540i XDrive
Ordered
I ordered the switch today, should have it tomorrow. From watching the video it looks extremely painful to remove. Do you think thats the proper way to remove the old one?
      05-14-2020, 05:23 PM   #25
in_uthero
Spain
Drives: BMW 5 g31
Does anyone have any news about this topic?
I’m still wondering if for my G31 I need to code or not the car.
I know it’s an old post but it would great to ear if someone was able to install and use the switch just like showed in the video...
      05-14-2020, 06:28 PM   #26
roxxor
roxxor's Avatar
1140
Drives: 2024 iX50
You would need to code it, but it’s only 1-2 codes in the seat module.
540iSUP703.00
      05-15-2020, 02:36 PM   #27
in_uthero
Spain
Drives: BMW 5 g31
Thanks roxxor. Since I’ve zero experience about coding, is it something complex or easy to do? Eventually, do you know if with bimmercode is possible to code it?
      05-15-2020, 05:16 PM   #28
roxxor
roxxor's Avatar
1140
Drives: 2024 iX50
Can’t remember if BimmerCode has it listed, but if the seat module has “expert mode”, then yes, you could do it with BimmerCode. Just changing the 2 “gentleman” values to “aktiv”
      05-15-2020, 06:15 PM   #29
in_uthero
Spain
Drives: BMW 5 g31
Ok, I’ll give it a try.
Thanks a lot, I appreciate!!!
      06-13-2022, 05:04 AM   #30
540iSUP
Drives: G30, E36
using Bimmercode, you must Activate Gentlemen function for BOTH passenger and driver seat. Menu looks like 3000 SM_Global>Gentlemen>Aktiv
I just purchased an Ivory colored switch for my vehicle from ECS tuning. Should be here next week or so. I'll let you guys know how it goes.
      06-14-2022, 05:59 AM   #31
r1cero
Drives: bmw 520d g30
Anyone able to decipher which part number is needed for this?
https://www.realoem.com/bmw/en/showp...diagId=61_6278
My interior is cognac, switch itself is black(schwarz) and I do have massage option.
I thought it was 61316997301, but it says CANBERRA-BEIGE in 'Supp.' column.
edit: on second look, I believe 61316997300 is what I need
540iSUP703.00
      06-15-2022, 12:43 AM   #32
540iSUP
Drives: G30, E36
I'm hoping I get the part. It now says backordered, we will see.
      06-17-2022, 03:31 PM   #33
Flakmunky
Amateur Brain Surgeon & Olympic Knitting Champion
Drives: E85, E92, F31, G31
Question... Can this be added to standard memory seats or is it just the comfort armchairs?
Wow, had this on every other car I've owned with electric memory seats and I was surprised it wasn't on my G31... I'm sure it was on my F31, but that was 7 years ago so maybe I can't remember...
Anyway, ramble over...
540iSUP703.00
      06-17-2022, 11:57 PM   #34
540iSUP
Drives: G30, E36
I think this can be added to any memory seats. My seats do not have cooling or massage, only heat.
      07-22-2022, 11:24 AM   #35
r1cero
Finally, got the time to install the new button. It was a pain to remove the old one, needed to break the clips like the guy in the video so not sure the old part can be used any more. Also new part seems to be more rounded than the old one so the fit is not ideal but not noticable to normal people.
Easiest part was the coding. Without coding, none of the functions work at all.
before
after
and the result:
View post on imgur.com
      07-22-2022, 01:53 PM   #36
ezaircon4jc
ezaircon4jc's Avatar
Drives: 2019 540i M Sport
Originally Posted by NeuBob View Post
I have black interior with massaging seats so i'm guessing number 3.
I also found this video: https://youtu.be/JlI1WgxPEXo
Seems like there is a change in code
before
after
and the result:
Is the coding just activating the function in both front seats?
      07-22-2022, 03:46 PM   #37
r1cero
Yes.
bimmercode:
1. seat module driver, enable expert mode > 3000 sm global > gentleman change to aktiv
2. seat module passenger, enable expert mode > 3000 sm global > gentleman change to aktiv
      07-22-2022, 08:09 PM   #38
WretchedRefuse
Drives: 2020 BMW M550i
Hi r1cero Could you let me know what part number you ordered? I have the black interior with massage seats so I should use the same part that you did. I think it would be 61-31-6-997-300 but wanted to make sure. Thanks!
      07-23-2022, 12:25 AM   #39
ezaircon4jc
Yes.
bimmercode:
THANKS! That confirms that the first switch I bought was defective. I plugged it in and even the "basic" functions didn't work, even with the coding. I have a new one coming from Lithuania.
      07-23-2022, 03:21 AM   #40
r1cero
Basic functions didn't work for me either, they started working after the coding. But if the bimmercode said coding successful and you were sure the connector was plugged in properly, than definitely broken part.
@WretchedRefuse
Yes, that's the one.
      07-23-2022, 03:05 PM   #41
ezaircon4jc
Basic functions didn't work for me either, they started working after the coding. But if the bimmercode said coding successful and you were sure the connector was plugged in properly, than definitely broken part...
I coded the function prior to installing the switch. The factory switch worked perfectly after reinstalling it. Think I should uncode then recode the function?
      07-23-2022, 04:49 PM   #42
r1cero
I would try it.
540iSUP703.00
      07-30-2022, 02:15 PM   #43
WretchedRefuse
Success! I installed the switch, coded my 2020 550i and everything works as advertised. Since I had previously installed the Bavsound speakers I knew how to remove the door card (not a job for the uninitiated!) Doing so allowed me to remove the factory switch without destroying the metal tabs. It added about an hour to the job.
540iSUP703.00
      07-31-2022, 09:23 AM   #44
540iSUP
Drives: G30, E36
Yes, removing the door card and pushing the switch from the back is definitely the cleanest way to go about this.
