BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding First attempt coding w Bimmercode
      04-19-2020, 09:13 AM   #1
obhitn3
obhitn3's Avatar
Drives: 2020 M5
Not great pictures but cool options to code the display on my m550i with BimmerCode. Check out the video too
2020 M550i x-drive
      04-21-2020, 05:41 PM   #2
Leindurstit
Gray Creature
Leindurstit's Avatar
17
Drives: 2023 M4 Comp xDrive
Have you come across any way to change the HUD options to show the M5-style tachometer and gear display, such as pictured in their marketing material? https://www.bmwusa.com/content/dam/b...arousel-02.jpg (assuming of course that the hardware is similar across the two models--it seemed that this was a definite 'no' on pre-2020 G30s.)
It's a bit annoying how little information is displayed in our fairly-big HUDs, excluding if you've got navigation running (even basic things like turn signal status or cruise control target speed not being there seems pretty short-sighted.)
      04-22-2020, 10:47 AM   #3
obhitn3
obhitn3's Avatar
Drives: 2020 M5
I will check later. Bimmercode is pretty limited, but gives you enough rope to hang yourself. I noticed the font on the HUD changed after going to the M dash, but with my polarized sunglasses, I have gotten in the habit of not looking at the HUD unless its dark. Let me see if it did anything else to it.
2020 M550i x-drive
      04-25-2020, 06:40 PM   #4
Rikes
Rikes's Avatar
93
Drives: G02 X4 M40i Carbon Black
I am about to bimmercode for the first time.
What does this mean?
Use a backup to revert this coding once it has been applied.
How do I backup?
      04-25-2020, 09:38 PM   #5
obhitn3
obhitn3's Avatar
Drives: 2020 M5
How do I backup?
The app will backup all of your current settings and store them in your device in case something does not go right. You can revert to previous settings. You should see the backup option at the bottom.
2020 M550i x-drive
      04-25-2020, 11:23 PM   #6
Rikes
Rikes's Avatar
93
Thanks....finally got it sorted.
Loving the Alpina instruments
      05-08-2020, 06:52 PM   #7
Tfb
Drives: G30 540xi f16 40d e70 30d
U live in Australia? so Hud will change in M settings?;-)
