05-04-2020, 12:53 PM | #1 |
Rep 25
Coding Failed - Need to restart FSCs
Hi everybody,
I have a little big problem, and iīm sure that this is the best place to get helped! Thanks very much in advance for your support! i have a BMW G30 of november 2017, and i wanted to install carplay in my idrive 6. For that purpose, i used HU Tools 2.6, and i generated an usb drive with all the supposed files required. I put it in my car, and after several rebootings, carplay was not enabled (it doesnīt suprised me), but the problem is that now Navigator doesnīt work, voice recognition doesnīt work, and all functions that require FSC donīt work. I tried to reinstall the operating system, downloading the last version from BMW.com/update, but these functions still donīt work. Is it possible to repair this failure? How should i do it? I dont have ENET cable, and donīt have knowledge on how to use E-Sys and these tools... Is there anything that i can do? thanks very much again, and regards. |
05-05-2020, 02:58 AM | #2 |
Rep 891
Hello,
You need to flash nbt back to stock and you might need a fsc repair set depending on what the patch has done. This can be done remotley. Using HU tool is a pretty much a miss if you are not 100% sure of what you are doing or you didnt check your istep version before. Downloading latest version from BMW website will not help. PM me if you need help. |
