BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Puddle lights - upside down! HELP
      05-10-2020, 05:03 AM   #1
devil84
Drives: G30
hi guys
was wondering if you can help. i bought the genuine m performance puddle lights and fitted them (can only fit one way in door during to wiring)
63312414105
here comes the problem, when its fitted, the image projects the wrong way rounds.
The projectors can only go in one way (tried flipping round) and it does not really rotate! I have tried everything flipping it round, don't really rotate much. I can only insert it on way in and i have tried both combo (left and right projector on the door)
I have tried all the projector images and all combo and same result...
any help would be appreciated.
      05-12-2020, 05:51 PM   #2
helidoc44
Drives: M2
I fitted these to my new G31. I had the same problem. There is a combination which gives this.....
However, I can't remember what I did, maybe swapped LH/RH light units and possibly also swapped LH/RH lenses. Sorry I'm not much help, but there is a combination...
2020 530d M Sport Touring, pretty standard but coded.
2018 M2, Met Grey, DCT, some options, and coded ....
2017 M140i, 2 door, Met Grey with red interior, a few options, and coded.
      05-15-2020, 06:19 PM   #3
devil84
Drives: G30
Hey bud. That looks good. I have tried all the combo. So frustrating. Is your puddle light the same part number as mine?
Any chance you can take a picture for of how it is installed if not too much trouble to pop off?
I am really at a loss..
      05-16-2020, 09:48 AM   #4
helidoc44
Drives: M2
Drivers door has the 'L' left light with the 'L' left image, Light/Lens towards the front of the car....
      05-16-2020, 10:13 AM   #5
devil84
Drives: G30
Thanks mate! 👍🏽 That's really strange. : Why is left on drivers door? 🤷 I tried the left and right image but did not change the unit 🙈as I assumed right means drivers! Thanks again
      08-03-2020, 04:24 PM   #6
Osheatwo
Drives: BMW M3 Comp Xdrive
2021 BMW X5 M50i  [10.00]
2023 BMW 330E  [10.00]
Did you get it fixed? If not you just need to pull the cartridge out and flip it over. This will put the BMW on top. The reason it's upside down on the G30 is because the wire connection is the reverse of all other cars. Most cars the wire comes from door hinge side but in G30 it comes from other side.
Since the wire is opposite you have the flip the lens the opposite way. Leave the Left one on driver side and right on passenger side so emblem will point outward.
I have a G30 but couldn't get them to fit in my car. Almost like they cut the hole to small for them to fit and didn't want to force them in.
Good luck.
      08-05-2020, 06:44 PM   #7
Skyrider01
Drives: 2019 M550ix, 2020 330i
I had the same issue when I installed mine. Even though they are labelled left and right, put them on the opposite side and that will take care of it. In other words, put the left one on the right door and vice versa.
      08-15-2020, 10:23 AM   #8
devil84
Drives: G30
Yep that's what I did and it solved.
      08-16-2020, 05:34 AM   #9
Petersen1979
Drives: G30 520i
Do they give the same”amount” of light as the standard lights?
      08-16-2020, 10:21 AM   #10
Skyrider01
I can't say whether they put out the same amount of light or not since they are colored and have a different light pattern.
They are LEDs and bright enough for me. Here is a picture of it with my car in my garage.
      10-05-2022, 05:28 PM   #11
That5erGuy
Drives: Bmw 5 series G30
Hi i had the same issue but i sorted it now the two front logo puddle lights driver side and passenger side do not come on but when i open the rear doors the front ones flicker 5 - 6 seconds. Any help please! Thanks in regard.
