01-21-2021, 11:32 AM | #1 |
Rep 13
2021 G30 - Run Flat / Space Saver Spare Urgent Questions
Hi,
First time poster on these boards - but from what I've been reading so far they are very helpful. I am in the process of placing an order in the US for a '21 G30 540i X Drive. I'm new to Run Flat Tires and have read many reviews on them and heard all the pros and cons. Let me get to the point of my questions. 1 - It seems that trunk floor is raised to accommodate the space saver spare - which will impact how flat the floor is and the rear folding seats are down. I'm concerned about how much trunk space I will lose. Can someone that has it show me a picture of how that looks - showing the rear seats folded down? 2 - Is it true that this cartridge unit raised floor can easily be removed? I would consider removing it except for when traveling on a long trip. 3 - If we are on a long trip and were to have an issue with the RFT tire and we drove to a shop but they couldn't get replacement RFT for a few days, would we be able to put on a Non RFT to replace the tire and how long could we leave that on? What is impact of driving with 3 RFT and 1 Non RFT? I appreciate your feedback on this topic so I can have peace of mind with my ordering decision. Thanks. |
01-21-2021, 11:51 AM | #2 | ||
Rep 546
01-21-2021, 02:06 PM | #3 |
Rep 608
I just took runflats off primarily as the ride on the 759i 20s was terrible.
I don't always have the boot that full so just ordered a 19 inch space saver. The scissor jack will sit inside the wheel so it won't take up too much space. The oem kit is a nice solution too. As an aside the PS4s tyres provide almost a blanket of insulation from the poor roads in Ireland. I wish I hadn't wasted over a year on the runflats. |
01-21-2021, 06:23 PM | #4 |
Rep 86
For $150, the space saver spare is a bargain for what you get, i.e. the wheel, tire, jack, tools.... You will loose about 4-6 inches of vertical space, but you can always remove it for local use - not hard to do. I didn't have it in my 2018 M550, but I got it in my 2021, and I don't have an issue with the reduced truck space. In reality, the 5 series trunk is not exactly spacious to begin with, so its no big deal to me.
01-21-2021, 06:38 PM | #5 |
Rep 93
Ordered the kit for $150. Was surprised how much space I lost. Going to take out the cartridge and spare soon and keep it in the garage. I need the trunk space.
luv2cruise4.50 |
01-21-2021, 07:58 PM | #6 |
Rep 454
luv2cruise Take a look at these pics I just took. Hope they will help you get an idea of the trunk space with the spare.
I only took out one, but both of these "cartridges" seem removable. Even with both gone the floor wont be flat with the folded seats. In other words don't think you can remove them and the trunk will look like a regular trunk with no spare. I only carry groceries in the trunk so it works for me, but you will most definitely lose trunk space. I did not have a spare in my 2018 540xi. I never again want to experience a 40 mile drive on a RFT with no air.
Current: 2024 540i MSport
Prior: 2021 540i MSport, 2018 540i MSport, 2015 BMW 528i MSport, 2012 BMW 528i |
mediocrechris40.00 |
01-21-2021, 08:47 PM | #8 | |
Rep 13
01-21-2021, 08:50 PM | #9 |
Rep 13
Interesting, I haven't had a tire issue in over 15 years, but I don't know how durable the RFT are. I kind of hate to give up the trunk space with what little there is in the first place. I'm coming out of a mid size SUV Acura so hard to even give up what I am.
01-21-2021, 08:53 PM | #10 | |
Rep 869
2 moon craters.
I have wheel and tire insurance. Changed myself once bc I was in a safe place and did not want to wait. The other time was on parkway. Used roadside to swap out. Quote:
01-21-2021, 08:58 PM | #11 | |
Rep 13
Thanks all. |
01-21-2021, 10:39 PM | #12 | |
Rep 2,946
Drives: 2020 BMW 530xe
Looks like from these pictures the spare tire kit makes the trunk as small as a 530e. What was the RFT experience you had? |
01-22-2021, 08:25 AM | #13 | |
Rep 13
I assume if you don't get the spare tire kit then that floorboard is lowered and it is flat directly above where the battery is then. Thanks again for your reply. |
01-22-2021, 10:34 AM | #14 |
Rep 263
For an extra $150 it's a no-brainer. You can always take it out and keep it aside if you need the trunk space. If you ever change to non run flats in the future, you will have the spare available. Buying it afterwards on its own is around $900.
That being said, I have non run flats and the spare tire on my M550i. I have never needed the trunk space where I had to remove the set up. I did remove it once to see how it worked and it's a quick and easy removal and reinstall. Around 5 minutes to take it apart and put it back together. |
01-22-2021, 10:54 AM | #15 | ||
Rep 608
Do mind me asking where you got the kit for $150? Thanks |
01-22-2021, 10:57 AM | #16 | |
Rep 263
01-22-2021, 11:53 AM | #17 |
Rep 263
OK, here you go.
With the spare tire installed: Spare set up removed As you can see, when you remove the spare, the floorboard drops about 6 inches towards the opening of the trunk and closer to 8 inches on the inside. And with the seats down, the floor and seatbacks are level, although the seats do tilt up several inches. |
01-22-2021, 12:29 PM | #18 | |
Rep 13
admranger2984.50 |
01-22-2021, 12:51 PM | #19 |
Rep 387
If you're stressing about the trunk space keep in mind that whole $150 kit is removable. The lid of the spare kit becomes the floor of your trunk. You can keep the kit in your garage if you're running RFT's. Put the kit back in when your running some nice Michelin Pilot Super Sports. The thing is if you decide you want the spare kit after the fact it's gonna cost you probably $700 to $900. Really a total no brainer to option the spare kit if your doing an ordered car. Never gonna use the spare kit- put it on eBay and quadruple your $150 investment.
Note: Fitment of rubber trunk mats are different with the kit installed. Weathertech makes a mat for the top of the kit when installed- see their ordering guide. With the kit out you can use the OEM rubber trunk liner from BMW, or get the standard Weathertech liner made for cars with no kit.
2020 540i MSport | Alpine White | Mocha Nappa | Aluminum Rhombicle | Exec Pkg | Luxury Seating | Bowers & Wilkins | Parking Assistance Pkg | MSport Brakes | Ceramic Controls | Space Saver Spare |
01-22-2021, 12:59 PM | #20 |
Rep 13
MauiSteve/Skyrider:
Yes I'm starting to get a much clearer idea of how this works - in that the lid of the spare kit is used as the cover when you take the kit out. I agree it's worth the $150 out and sounds easy enough to remove (and it's in the manual) so I can keep it out when I'm local, but put it in on longer trips across country. The pictures Skyrider posted showed EXACTLY what I was looking for. I don't know if the trunk configuration of the M550 vs 540i would be the same, but I can't see why that part of it would change with the kit and lid for it. You both have been very helpful. Though, I'd much rather be driving my upcoming new car on Maui up to Haleakala than on the roads around here. Thanks |
01-22-2021, 01:45 PM | #21 |
Rep 263
01-22-2021, 01:58 PM | #22 |
Rep 13
Would you agree that the trunk configuration in the m550 and 540i would be developed in the same way, meaning the cover would fit even if the kit was removed as you have showed in your excellent pictures?
Tags |
540i, g30, rft, spare |
