BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis 705m F90 wheels on G30
      07-12-2022, 01:35 PM   #1
cna90
cna90's Avatar
Drives: BMW 540ix with MPPSK
Have any one tried 705M f90 wheels with wider tires on G30?
I only see this thread that has the OEM width on it without any issues.
I'm looking at buying a set of 705Ms and fit wider 255/265 front and 285/295 rear and want to make sure they fit as the offset is quite different than the OEM.
Photos would be great too.
      07-16-2022, 12:40 PM   #2
peteinpa
Albania
396
Drives: 2013 535xi
I have them. The offsets are aggressive for a G30. You will have slight poke. I went with 275/30 on all 4 corners even though the rears are wider. I also added wheel arch extensions for the rear so the poke is not as noticeable
Some pics.
      07-16-2022, 11:56 PM   #3
cna90
cna90's Avatar
Some pics.
That's it. Thanks. That's what I wanted to know.
Seems like 295s are not gonna work. I was gonna also increase the side wall by %5 all around for a more comfortable ride. For sure 295s are gonna rub.
      07-18-2022, 02:11 PM   #4
bmw5er4life
bmw5er4life's Avatar
Drives: G30 M550 and G12 740
Some pics.
You can find these on ebay as well. Not oem but can't tell the difference besides the width. Ended up going with it on my car and it is a perfect fitment.
20x8.5" front with 245/35 Michelins
20x9.5" rear with 275/30 Michelins
Previous BMWs: F10 528i M Sport, F10 535i M Sport, F10 LCI 535i M Sport, G30 540i M Sport
Current: G12 740i M Sport, G30 M550i xDrive
      07-18-2022, 10:11 PM   #5
cna90
cna90's Avatar
Some pics.
There is a guy close to me selling reps actually. I'm thinking if bimmer rim's bent, those with definitely going to bend in Toronto.
      07-18-2022, 10:47 PM   #6
bmw5er4life
Some pics.
They're mostly all alloy wheels, OEM vs reps. No wheel is an exception to potholes etc, even forged wheels. Basically any wheel at any point can crack or bend with impact
      07-18-2022, 10:57 PM   #7
cna90
cna90's Avatar
Some pics.
Fair enough. With these tiny side walls on RFTs there is no chance.
      08-08-2022, 12:37 PM   #8
nizmugen
Drives: E39 M5, G30 530e
Some pics.
Are you lowered at all? I have the same wheels (in storage) and about to start prepping to install with H&R springs.
      08-08-2022, 01:29 PM   #9
peteinpa
Albania
396
Drives: 2013 535xi
Some pics.
No sir I am not lowered. Looking forward to seeing yours with wheels and lowering springs installed. I would be concerned with rubbing given the slight poke but from what I have heard camber is adjusted when lowered so you may be ok.
      08-08-2022, 01:38 PM   #10
cna90
cna90's Avatar
Some pics.
Just to make sure; you've got 706m 20", right?
705m is 19"!
      08-08-2022, 02:06 PM   #11
peteinpa
Albania
396
Drives: 2013 535xi
Some pics.
705m is 19"!
Yes they are 706m 20".
fronts are 9.5 wide rears I believe are 10" wide.
      08-09-2022, 10:14 AM   #12
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Some pics.
705m is 19"!
Here's the OEM M5 wheel sizes.
19" 705M are 19x9.5 ET26 and 19x10.5 ET28
All the 20" are 20x9.5 and 20x10.5 both ET28.
peteinpa396.00
      08-16-2022, 11:12 AM   #13
nizmugen
Will update you once everything's in!
      09-25-2022, 11:43 PM   #14
nizmugen
peteinpa do you have any closeup photos of the rear fitment? I test fitted the rear (without a tire) and the offset was concerning, thanks!
      09-26-2022, 04:45 AM   #15
peteinpa
Albania
396
Drives: 2013 535xi
Here you go. There is a slight poke. I ended up adding wheel arch extensions, poke is not noticeable. I also went with 275/30 tires on the rear. No rubbing with the slightly smaller tire. The pic is with a 285/35 tire.
I will take a pic with the arch extensions and post a little later today.
      10-05-2023, 10:15 AM   #16
Alberto540i
Alberto540i's Avatar
Drives: BMW 540i G30
One question, why do the wheels protrude more than the m5 f90, the rear part is equally wide in both models, right?
      10-05-2023, 03:37 PM   #17
remmib
remmib's Avatar
Norway
1569
The M5 has a different rear suspension with narrower track width.
      10-05-2023, 03:39 PM   #18
Alberto540i
Thanks for the response, I was just thinking this.
