BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Aggressive wheel fitment for M550
      07-16-2019, 10:18 AM   #23
CLABRO
THUNDER UP!
CLABRO's Avatar
Drives: BMW M Sport G30
Originally Posted by x427x View Post
I'm planning to order a set of wheels with parameters 9J +25 10.5 + 38 and put tires 255/30 and 305/25 - could anybody advise will this work?
255/30 and 295/25 will work for sure, but what about rears with 305/25 as for me it will be better for 10.5 and fronts with 255/30
Yeah 305 will work. Minimum wheel width would be 10.5" for a 305.
However, there's more of an issue with the diameter or height of the tires you mention. They're shorter than the OEM tires. Depending which manufacturer you go with, they will be ~ 7" - 11" shorter than OEM tires which will give you more gap between the top of your tire and your fender.
You're better off going with tire sizes that are closer to OEM factory specs, IMO. You typically want to get as close as possible. It'll look better and won't give you as many side effects (speedometer being off, worry about them not fitting or rubbing, etc).
EDIT: I don't want to hijack the OPs thread so go out and see what tires you currently have and size then make a new thread with that information and people can help you out.
G30 l Alpine White l M Sport Package l Executive Tier l Icon Adaptive Full LED Headlights l Mocha Nappa Leather l Multi-Contour Seats l Drivers Assistance Package l Drivers Assistance Plus Package l Dynamic Handling Package l Parking Assistance Package l Bowers & Wilkins Diamond Surround Sound System l M Sport Brakes l Apple Carplay
      04-08-2020, 10:37 AM   #24
Madmachinist
Drives: 2016 550i M Sport
Does anyone know if a 19x9.5 wheel would fit the the front of a 2020 M550ix without rubbing and if so, what offset I should look for?
      04-08-2020, 01:09 PM   #25
Superjackson
Drives: M550i
It fits with 28 offset, but you need to lower the car for it to not stick out past fender.
      04-08-2020, 02:08 PM   #26
Madmachinist
Thanks Jackson. Will the tire rub if the car is not lowered?
      10-28-2020, 03:54 PM   #27
Dheeth-G80
Dheeth-G80's Avatar
226
Drives: 2021 G80 M3C
Originally Posted by Dobie Dog View Post
Here is a 20x10.5 ET35 on the rear of mine for comparison.
Would 295 fit on et35 20x10.5 in the rear?
2021 G80 M3C - Current
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      10-30-2020, 10:56 AM   #28
Overlord73
Overlord73's Avatar
Drives: Carless
I've been researching this as well to my understanding a 9.5" with at 25mm offset up front will be aggressive and pretty much flush with the right tire size I'm looking at 255/40, 265/35 may work as well, I've been looking at a set of Gramlights and this width and offset is shown as a tuner fit on G30 which seems to indicate aggressive. There is another member who has posted pics and is actually running this exact spec with stock 245/40 and it looks hella flush but a bit stretched tire wise.
      11-27-2020, 09:09 PM   #29
tamkin_anwar
tamkin_anwar's Avatar
Drives: BMW 530i
Looks good! It will look great when lowered! My offset is et38 as I was making room for 295 tire.
Which rims are these?
T.N.A
      11-28-2020, 09:59 AM   #30
jlcf22
Drives: 335i09
HRE FF01
      01-12-2021, 09:19 AM   #31
jesse_g30
jesse_g30's Avatar
Drives: G30 540i xdrive, E36 328i
Question
looks great, i was wondering what wheel and tire size you were running, also where did you get your front lip and side splitters, they look amazing!
      01-12-2021, 07:17 PM   #32
Rodders2018
Drives: BMW M550
If we do math... example:
Stock 19” Rear is 9”Rim w +44mm. So overall stack = (9/2 x 25.4) +44 = 158.3
I am looking at a 20” Rear 10” w +40 which based on formula = 167mm
That would put the rear wheel lip .355” out from stock wheel. Yes?
Same logic in front
R19 x 8 w +30 = 131.6mm
Option
R20 x 9 w +38 = 152 mm
Difference +.815”
Am I doing this right???
      01-14-2021, 02:15 AM   #33
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
No, rears will be 17mm more out, and the fronts 5mm more out.
You calculated the inside difference.
      01-18-2021, 02:05 PM   #34
Rodders2018
Drives: BMW M550
So the offset is inside measure... thanks.
      03-09-2021, 07:58 PM   #35
particulardude
particulardude's Avatar
Drives: LR4 | L405 SC SWB
Ah search works! This is exactly the info I was after - thanks all !
This thread needs more pics!
      12-16-2021, 11:07 PM   #36
Rodders2018
Drives: BMW M550
Same logic in front
Option
Difference +.815”
Can we put 295/30 on rear with 10” wheel above? I assume I can as the 295 is 11.8 width and stock wheels at 9” with 275 are 10.6” actual.
      05-30-2022, 07:12 AM   #37
Merciless58
Merciless58's Avatar
65
Drives: 2012 F10 M sport
Bump, as I will be upgrading to a G30
      05-31-2022, 11:15 AM   #38
Boosted_8
Drives: M550i
I've 285's on a 10" rim right now. I would say 295 is totally fine.
