BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Can we install rear aircondition controller and rear blower by ourself?
      08-25-2019, 07:58 AM   #1
F10Thai
Thailand
Drives: 530e G30 / 528i F10
I find the used rear controller and rear blower in ebay. Can i do install those things by ourself? Anyone has wiring diagram or pictures how to install those?
      08-25-2019, 08:18 AM   #2
nlaak
Drives: 2020 BMW M5
The car will likely need be programmed/coded for this after the install, so you'd need the advise of some (very) experienced people about what can be done.
clee1982797.50
      08-26-2019, 08:01 AM   #3
Mach550
Mach550's Avatar
Drives: 2019 M550i
2019 BMW M550i  [8.00]
I was thinking about just buying the HVAC piping that goes from the rear of the center console out to the B pillars. It goes under the carpet so it won't be an easy job.
      08-26-2019, 11:38 AM   #4
nlaak
Drives: 2020 BMW M5
I would assume the ducting is there already, considering most cars (and I assume the G30) have ducts in the rear, they just don't have controls and relays/fans/etc to enable/disable air flow to the rear.
      08-28-2019, 10:27 AM   #5
Mach550
Mach550's Avatar
Drives: 2019 M550i
I really doubt they put the plastic ducts going under the seat to the B pillars...you can see it in the bottom left of the picture
https://www.realoem.com/bmw/enUS/sho...diagId=64_2271
clee1982797.50
      08-28-2019, 01:07 PM   #6
nlaak
Drives: 2020 BMW M5
I'm not sure what you're saying here. There are clearly ducts in the image and the part description from the web page.
The point I was making was that most (all?) cars have ducts for the back seat and I can't see them omitting them just because you don't have 4 zone climate control, you still need heat and cooling to the backseat, even if you can't control it.
      09-17-2019, 02:02 AM   #7
Momo Jch
Momo Jch's Avatar
Drives: BMW F34 330
It's ok, but it needs programmingI have already installed it.
      03-23-2021, 01:59 PM   #8
Zeroheight
Zeroheight's Avatar
24
Drives: 2018 540i M Sport
2018 540i  [0.00]
beside programming, is there anything else needed to get rear controller working?
