06-16-2023, 04:46 PM | #1 |
Rep 59
Drives: 2023 BMW 530e
Which battery should I disconnect when working with BDC?
Hi, I'm doing the retrofit for the Gesture control. As a part of it, I'll need to access connector for A258*8B I'll need to disconnect it, then add 2 wires to it. I'll also need to disconnect the sunroof controller to replace it. And I'll be adding the other ends of the wires to a connector there.
Do I need to disconnect any battery for this project? If so, which one? I'm in a 2023 530e, so it's a hybrid. In the trunk, I see one battery on the far right, and another in the middle of the trunk. See pictures. Which one should I disconnect if any? I'm nervous to touch the terminal. Last year, I was helping my daughter jump start someones car (not using mine) and I clipped the black / red the wrong way... it didn't really go so well! The jumper cable sparked and in 5 seconds burst into flames! So, I'm nervous to touch this the negative terminal on my BMW. I also read, that if I do this wrong, it will ignite the airbags. Am I missing something? Thx! |
06-16-2023, 05:32 PM | #2 |
Rep 1,185
Drives: 2023 M550i CBM/Ivory
hopefully someone who has actually done it can give you some instructions/recommendations. wishing you luck!
06-17-2023, 11:33 AM | #3 |
Rep 7,580
To remove the BDC...ALL battery earth leads MUST be removed. This means the main battery (the one in the middle) and the auxiliary battery (the one on the side). REMOVE their negative battery cables…and make sure they DO NOT touch anything metal. Wrap the terminals in an rag, towel, or even an old sock…to prevent any accidental shorts in case the cables get bumped or move and end up touching something metal.
But since you have a hybrid…you also have a high voltage battery…and hopefully you’re prepared and understand how to work with this special battery because its earth lead must also be disconnected: Work on live high-voltage components is expressly prohibited. Before each operation on the high-voltage system, the system must be isolated from the power supply by qualified personnel (high-voltage safety connector Off) and secured against unauthorised recommissioning (padlock).
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
06-18-2023, 11:25 AM | #4 | |
Rep 647
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
Tags |
530e, battery, disconnect battery, g30, hybrid |
