BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Activating SLI on Non-SLI Country
      12-07-2019, 02:33 PM   #1
ejlover06
ejlover06's Avatar
Turkey
105
Drives: 2017 G30 520 1.6lt
Exclamation Activating SLI on Non-SLI Country
Greetings,
I live in Turkey and BMW doesn't give SLI service in my country.
I've been told in another forum that SLI can be activated for my car so I've paid for FSC and remote coding. Today we've coded the car. SLI sign appeared on instrument cluster and HUD as (---) but KAFAS2 doesn't read any traffic signs (they are in Europe format).
They are telling me that my maps doesn't have speed info which I've already told at the beginning. Since BMW doesn't give SLI service in my country means that they don't put speed info in their maps....
I've had coded my Mercedes (W205) in 5 minutes and activated SLI and it doesn't also have speed info in its map.
Can we read signs via KAFAS2 and display them in the cluster without any need of map data? Or in any way is there a possibility to make this work???? I really need some support about the matter since I've paid significant amount of money for nothing...
As it can be seen below SLI (S8TDA) has been coded to my cars VIN:
But no signs are being read. And back ground of sign icon is grey. Should it be white?
2017 G30 520 (1.6lt)
2016 S1000RR
2014 W205
      12-16-2019, 03:54 AM   #2
ejlover06
ejlover06's Avatar
Turkey
105
Question
As an update we've disabled S8TDA. And recode everything accordingly but SLI still didn't work on my car
How can it be enabled in a non-SLI country?
2016 S1000RR
2014 W205
      02-21-2020, 03:23 PM   #3
ejlover06
ejlover06's Avatar
Turkey
105
Talking
Finally made SLI to work in a non-SLI supported country
2016 S1000RR
2014 W205
      02-21-2020, 03:25 PM   #4
LogicalApex
Drives: 2020 BMW 530xe
2020 BMW 530xe  [0.00]
Great! What did you do? In case someone else comes around this thread and needs some guidance.
      06-19-2020, 02:08 PM   #5
up2up
up2up's Avatar
Drives: X5M 2019
could you help with the activation please?
Abdol (X5m, 2019)
      06-20-2020, 07:29 PM   #6
Tavinho
Drives: BMW X5 F15 M50d
What did you do? I have the same problem you used to have, since I live in Brazil and here the signs correspond to the European model, but my X5 has SLI activated and does not read speed signs... could you share the solution pls?
      06-22-2020, 11:23 AM   #7
up2up
up2up's Avatar
Drives: X5M 2019
Same problem.. it will be great if we could have the solution please
Abdol (X5m, 2019)
      07-02-2020, 06:59 PM   #8
kubax86
kubax86's Avatar
Drives: M2
It has to be coded properly to get it working.
      11-28-2021, 09:12 AM   #9
Ahmaddoski
Drives: 2020 bmw 330i Us spec
My car came with sli from factory but it’s not working in my country can you show me how you enabled it ?
      12-01-2021, 07:14 AM   #10
ejlover06
ejlover06's Avatar
Turkey
105
What do you have in your screen? --- icon? or nothing at all?
2016 S1000RR
2014 W205
      12-01-2021, 08:59 AM   #11
Ahmaddoski
It's imported from usa it already have sli but it's not working in my region, it worked when the car was in UAE but now it's in iraq and it's not working
      12-02-2021, 04:29 AM   #12
ejlover06
ejlover06's Avatar
Turkey
105
You must lift the country restrictions manually in the related parameter by modifying hex codes of the country you are in; but sorry I am not familiar with iD7 system
2016 S1000RR
2014 W205
      12-02-2021, 06:56 AM   #13
kubax86
kubax86's Avatar
Drives: M2
PM if need help. Fixed many already.
      02-19-2022, 09:19 PM   #14
oliveiac
Drives: X5-G05-2021
Tavinho did you done activate sli in your X5? I have X5 45e in Brazil too but SLI won’t work to read speed limit signs.
      02-21-2022, 03:54 PM   #15
mrgicm
mrgicm's Avatar
441
Drives: BMW M
In kafas you change the hex short coutry code for your country.
      02-21-2022, 04:59 PM   #16
kubax86
kubax86's Avatar
Drives: M2
Can be easily fixed by proper coding
      08-08-2022, 01:27 AM   #17
delimandarin
Drives: Bmw f10
greetings,
i live in turkey and bmw doesn't give sli service in my country.
I've been told in another forum that sli can be activated for my car so i've paid for fsc and remote coding. Today we've coded the car. Sli sign appeared on instrument cluster and hud as (---) but kafas2 doesn't read any traffic signs (they are in europe format).
They are telling me that my maps doesn't have speed info which i've already told at the beginning. Since bmw doesn't give sli service in my country means that they don't put speed info in their maps....
i've had coded my mercedes (w205) in 5 minutes and activated sli and it doesn't also have speed info in its map.
can we read signs via kafas2 and display them in the cluster without any need of map data? Or in any way is there a possibility to make this work???? I really need some support about the matter since i've paid significant amount of money for nothing...
As it can be seen below sli (s8tda) has been coded to my cars vin:
but no signs are being read. And back ground of sign icon is grey. Should it be white?
merhaba kardesim bana nasil yaptigini soyleye bilirmisin bende azerbaycandayim fakat calismiyor yardimci ola bilirmisin? Bende f10kasa. +994516993969 yardimci olursan cok sevinirim Esys program felan hersey var sadece nasil yapa bilirim diye oğretirsen memnun olurum ❤️
      10-05-2022, 11:42 AM   #18
cooper_se
Drives: MINI Cooper SE
Same problem as well, SLI enabled from factory but shows only (---) in instrument cluster & hud.
Can it be fixed by BimmerCode? Don't have cable or e-sys.
      06-23-2023, 06:28 PM   #19
ionko0007
Drives: BMW F01
Same for me.. My worked in Germ as NY but here in Bulgaria no.help please ionko0007@Gmail.com
      06-24-2023, 05:32 PM   #20
Siki78
Siki78's Avatar
136
Drives: F30,G30
Yes can be fixed need enet cable
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      07-08-2023, 05:23 AM   #21
bmwziastas
Drives: Bmw F11
anybody can virginize kafas4 remote?
      07-09-2023, 04:12 PM   #22
kubax86
kubax86's Avatar
Drives: M2
Sure, no problem at all.
KAFAS4, KAFAS4 Mid/High possible
